Ir para o conteúdo principal
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 Perguntas Visualizar todos
Can you replace the home button and still retain functionality?
Just looking to retain home button function, I am not concerned about retaining Touch ID.
If it can't this is going to push along of schools into paying for apple care.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Solução escolhida
Replacing the Home Button will not retain the TouchID functions but it will allow you to "push to click". If you want to change the HB yourself, check out this guide.
Esta resposta foi útil?
Pontuação 5
2 comentários:
That guide only tells you how to remove. I have found no documentation concerning home button function after replacment.
Just wanting to see if Apple pulled the same trick with the home button that they did with the iPhone 7 and 8.
por
It's a physical actuator, just like all the iPhones before the iPhone 7. You can see it in the picture above (that little black dot in the middle of the button). So if you change the button, you maintain "push-to-click". The iPhone 7 has a solid state button which is why replacing it kills all functionality.
por
Nathan,
On the iPad 6 if you replace the home button it will continue to work as a home button without Touch ID. The issue regarding the iPhone 7/8 was due to it being a solid state button, while the iPad 6 button actually physically moves.
I hope this helps,
Charlie B.
Source: 2 Years experience
Pontuação 2
1 comentário:
Do you mean after screen replacement with original home button still Touch ID will not work ?
por
Pontuação 0
Adicionar a sua resposta
Nathan Selby será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 4,286
