Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
471 Perguntas Visualizar todos
No output on display
Hi all,
I have an iMac (mid 2011 21.5) where the screen will no longer come on at all. The HDD had failed, I replaced it and put it back together but now I get no output. I cannot check if an external display would work because I don't think the iMac's display anything till booted on an external display (cant boot the Mac cause the HDD is new with no OS).
The connectors for the screen look to be seated right and I have tried to re-seat them also.
All 4 diagnostic LEDs light up on the Logic board but I still get no output on the screen.
Any advice would be appreciated.
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Hi,
Thanks for this, all connections are sound in place and all look intact.
The Mac boots into Internet Recovery but only when the internal display is unplugged, is this normal? Or could something in the screen be causing the Mac not to boot?
Thanks.
por
It could be that the backlight on the display died. Try shining a light onto the display when it is turned on and see if you see a startup screen or icons.
por
Hi,
Thanks all! From what I can see/ can’t see, there is no image at all on the screen.
por
Adicionar um comentário
2 respostas
Try a pram reset . if that brings nothing try connecting an external display and try and enter into network recovery. When trying this you should see something on the external display,
https://support.apple.com/en-gb/ht204063 -PRAM REST
https://support.apple.com/en-gb/HT204904... RECOVERY
Esta resposta foi útil?
Pontuação 0
Please make sure this cable is well positioned and connected properly.
(please check the link)
iMac Intel 21.5" EMC 2428 Hard Drive Replacement
Otherwise, you should check other wirings aren't broken.
Pontuação 0
Adicionar a sua resposta
Dan Poulter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 78
