Ir para o conteúdo principal
Will the JDS-040 fit on my ps4 controller when mine has JDS-050?
My Controller model is CUH-ZCT2U and the model of the port is JDS-050 so i wanted to make sure before i bought anything that might not fit, and if i do need JDS-050, where could i find one ive looked everywhere but i cant find it.
JDS-050:
JDS-040:
Esta pergunta é pertinente?
Pontuação 2
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
I am in the same boat, need a jds-050 usb board and all I can find is the jds-040 board.. I'm gonna just order that one, the pin connectors are the same and had seen a wire diagram where they match the same, I am thinking the jds-050 was either an upgraded board or maybe a differnt manufacturer.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Same problem. Already tried a jds-040 board. It is not compatible.
por
so either buy a new controller or wait till they release the jds-050 to consumers
por
I have a CUH-ZCT2U (5th gen) and my controller has a JDS-055 board. My controller works when connected to USB but will not charge. I bought a JDS-040 board by mistake. The JDS-040 can be installed in the controller but the ribbon connector is on the other side and requires the ribbon cable be twisted to make it work. The JDS-040 does allow the controller to work over USB and the lights work but still not charging.
por
Adicionar a sua resposta
BurnedSpaghetti será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 89
Duração total: 5,059
