Why won't my speaker charge?
I plugged in the speaker to charge it, but the charging light won’t turn on and the speaker won’t charge. I also think some water got into the port.
Esta é uma boa pergunta?
If your UE Boom speaker does not charge, see the UE Boom Won’t Charge or Loses Battery Quickly problem page for possible causes and solutions.
So there is a couple of possible issues here. Try the following then reply to me.
1. Plug in the charger and move it a little, Be careful. Is there any movement when you try to move the cord around in the port?
2. Are you using a known working OEM charger for this item?
3. It is possible that the water got on Caps and other components on the motherboard. This will require a special set of skills to repair.
4. Did it work right before it had exposure to water?
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 63
Duração total: 4,102
por Shawn Blair
1. Tried that,nothing.
2. I am using the same one that came with the speaker.
3. I think some water got into the place were the charger is supposed to go in.
4.yes it worked just fine
Thanks for your answer
por Yasmin Dallol
