Ir para o conteúdo principal
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
80 Perguntas Visualizar todos
Its wont start when I tap start button. also indicator light is off
My psp is not real. its clone. its G39. At first I tapped the start button, it wont start. but indicator light worked. now it also wont work. pleaseeee help meeeee!!!!
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
If it’s not real then I doubt anyone can help. The whole design will be different to a real PSP.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Actually its same thing. You can only say the way to repair and I might try that. will you say?
por
The G39 is a copy of the PSP. Therefore it will not use the same components as a real PSP. If you want to start somewhere take it apart and look for obvious damage to the logic board. However you won’t get anywhere as this is cheap Chinese device with no technical support.
por
Adicionar a sua resposta
SA Shafi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 50
