Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
MacBook Pro exposed to inverse current
The power cord for my MacBook pro had broken again - the wires connecting to the converter were worn out - and I was reconnecting the wires. I'd done this repair a few times before so it was a routine process for me. Unfortunately, i was quite dimwitted when I was doing it this time and connected the white wire to the black one and vise versa. I plugged in the magsafe to my laptop with the wires crossed and exposed it to reverse current. Now my computer will not accept a change. The magsafe lights do not turn on when plugged in (with the power cord wires connected in the correct way. I tested the power cord on my brothers laptop and it works) so the issue is with my laptop. I immediately thought resetting the SMC settings would fix it but I've had no luck with that. The computer has been my trooper for the past 7 years still works fine aside from not being able to accept a charge. Any ideas on a repair? Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thanks Noah! I ordered that part and will let you know if it fixes the problem.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Oh my goodness so sorry to hear this! Those Mag Safe chargers are so expensive I have also fixed a few over the years. Now, this is probably a isolated incident only affecting the DC-In module.
I suggest you go Here to buy a new one and replace it.
The guide for that is Here
Hope that fixes the problem, though I don't believe it would spread any further than that module.
Hope this works for you, keep us updated.
Cheers
Noah
Imagem de MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Produto
$9.99
Esta resposta foi útil?
Pontuação 2
1 comentário:
Noah,
Thanks for the fix! I'm happily typing this on my newly charging MBP!
Andy
por
Adicionar a sua resposta
Andy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 53
