Ir para o conteúdo principal
The first iteration of Studio Beats headphones were manufactured by Monster in 2008. They are available in a large variety of colors. Screwdrivers, plastic opening tools, and possibly a soldering kit may be required for repair of this device.
Can I replace my headphones's ear cushions?
My puppy somehow for some reason got hold of my Beats by Dre headphones. Probably thought it was a play toy, which kind of still makes it difficult to explain as to how he got a hold of it. My cushions are all teared/ badly damaged. Headphones still work, but just the cushions damaged. Is it possible to replace? If so, please advise of any legit/ authorized repair company in the Western Cape, South Africa.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
I don't know how possible it is to replace the cushions; but you could go on Ebay and try to buy a set of headphones which don't work, but which have good cushions. You could probably get one cheap that way, and then get the cushions off of it and put them on your headphones.
Esta resposta foi útil?
Pontuação 0
Yes, if I am correct the ear cushion is fixed with double sided tape. Just search on Google for ear cushions and your type of Beats by Dre headphone if this is the case. Ear cushions at regular headphones have some kind of elastic band to hold them in place and are easy to swap with a new pair.
You can buy them at eBay indeed. So it should be an easy DIY job, no need to go to a repair shop. In the case you are going to a repair shop they could not really mess up your headphone, not in a way another repair shop couldn't fix it anymore.
Pontuação 0
Hi @mrjimphelps and @noob99 thanks for the respond guys... I thought as such. DIY way it is. Thanks!!!
Pontuação 0
Adicionar a sua resposta
Graham será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 1,473
