Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930, Versions: G930F (Global); G930FD (Global; Southeast Asia); G930W8 (Canada).
Fingerprint won't work after screen replacement?
Hi,I ordered a new LCD and touchscreen on aliexpress and went to the local store to replace it,now the screen is working but the fingerprint won't work,it always say:"Make sure that the Home key is clean and dry, then try again" but the button is clean and dry.I tried to restart it but nothing. At the local shop they said that they could reinstall the system for some money,my question is, can I reinstall it by myself and how or does someone have the same issue and a working solution?Thanks...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Does the home button work fine? It sounds like it could have possibly been broken during the repair. I highly doubt that restoring the phone to factory is going to fix this issue and even if it does, the repair shop should do this for free. It was working prior to repair correct?
Esta resposta foi útil?
Pontuação 0
The home button works perfectly,it was working on the first LCD...
Pontuação 0
Adicionar a sua resposta
axel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 214
