Why won't Whirlpool Model# WTW4816FW2 washer spin? Goes back to wash
Washer rinses, and when it goes to spin cycle, the spin light comes on, but it does not spin. Washer's wash light comes on, but does not rewash. Help!
Esta é uma boa pergunta?
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Esta resposta foi útil?
I was able to fix mine by (seriously) unplugging it for ten seconds and then plugging it back in.
You need to unplug it for 1 minute to reset it.
Answer: Washer machine door lock.
Hi , I have the same model : WTW 4816 FW 2 Whirlpool ! I am lucky enough to have a box of spare parts . I have replaced the Lid Switch with a new one. Shifter with new,Water inlet valve with another one, Computer with another . Drain hose replaced with new so far . It still washes and starts to spin and stops ? My brother was in the repair Biz before he passed . Taught me a lot but not these new Washers with computers ? I think the computer is bad ? I will post more info after I finish tonight .
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 92
Duração total: 6,538
5 comentários
So I understand... The washer fills and begins the wash cycle, agitating the clothes. Then it drains, and starts the spin cycle (indicated by the spin light) but does not spin. Then the wash cycle light comes on. Is this correct? Do you hear any noises when the spin cycle starts? How much time in between each event? Will it sit there doing nothing with the wash light on indefinitely? Have you tried leaving the washer unplugged for 10-30 minutes?
por Tim D
Once the spin light comes on, it is a matter of seconds before the wash light comes on. The spin light stays on too. It would sit there indefinitely. We tried unplugging for about 30 minutes. Did the same thing again
por Gail Greenley
The washer is six months old.
por Gail Greenley
Our apartment is equipped with this model wtw4816fw2 and makes a chugging noise like "the little engine who could"chug, chug,chug,chug it is not during spin. Happens on wash cycle. Sound is very loud . Help
por Barry Novick
Gail,
Did you ever find out what the problem was? I came across this page while on a Google search. I have the exact same issue going on with the exact same washer.
por Sarah Claypool
