Ir para o conteúdo principal
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 Perguntas Visualizar todos
Note 4 Motherboard Vibrates But No Fisplay
This question is in regards to a Note 4 (T-Mobile) motherboard.
When attached to a fully working screen and powered up, the phone will display the following symptoms:
1- The phone will vibrate.
2- The blue light at the upper left hand corner of the screen will pulsate slowly.
3- There is no display on the screen whatsoever.
4- This motherboard was connected to 3 different screens with the same result.
Any one has any idea what is the cause of this.
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
You can try
Powerbutton+homebutton+volume down... when come downloadvmode you can try flash with PIT, when not come this mode is 90% NAND ic problem.... - dead board
Esta resposta foi útil?
Pontuação 2
Thanks for the reply.
This motherboard ended up in the garbage.
Pontuação 1
Adicionar a sua resposta
Khaldoun será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 44
