Stops at spin cycle with UL
what do i need to fix if it stops on spin cycle with UL. its spins in one direction for couple seconds then stops n starts to spin in opposite direction...it does this back n forth over and over but never goes into spin cycle
Esta é uma boa pergunta?
4 comentários
My washer does that Ul code at the final spin the entire bucket moves uncontrollable the the ul codes appears
por Julie Cruz
@Julie Cruz
What is the model number of the washer?
Bucket moving about might be a problem with the suspension rods.
knowing the full model number will help to find the correct part if they are faulty/broken etc.
por jayeff
Maytagz quiet series bravos 300
por Lee Hart
@Lee Hart
if it is the suspension rods that are the problem, knowing the model number will ensure that the correct parts are listed in an answer.
por jayeff
