Repair guides and support for Android-based smartphones in Samsung's Galaxy S line.
4102 Perguntas Ver todas
What is the best tape or glue for rear glass and digitizers?
What is the best way to reattach the digitizer and rear glass on samsung galaxy devices S5 and up?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
I use ZHANLIDA B-7000... its glue... not tape...
Esta resposta foi útil?
Pontuação 0
Comentários:
is this permanent though? if i have to replace a part on phone again while i be able to fix again?
por
its really strong glue, like chemopren base... but with isopropanol posible remove
por
perfect thank you i will try this!
por
Resposta Mais Útil
Kristina, here is an adhesive made for the s5. It is only $5.99 and you can order it right here. Enter the Item Code below in the search bar and you can check it out. I hope this helps. Please let me know, Thanks, John
Galaxy S5 Touch Screen Adhesive
Item code: IF236-043-1
Pontuação 1
usually 3m double side tape
Pontuação 0
Comentários:
do you have a link to where i can buy some that doesn't cause the screen to lift
por
Adicionar a sua resposta
Kristina Saunders será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 73
