front indicator light not flashing; otherwise fine
macbook pro 17" ... just added RAM and cloned hard drive. everything working fine but the front indicator light isn't flashing. what causes that?
Esta é uma boa pergunta?
The status of the light tells you about the sleep status of the MacBook:
1. Not glowing -- the MacBook is awake or powered down. (The difference is usually obvious: when awake the screen is lit.)
2. Glowing steadily: either the screen (only) is asleep or the drive is spinning down as the MacBook prepares to go into full sleep mode.
3. Pulsing: the MacBook is asleep, the drive has spun down & its heads are "parked," putting it in its most shock-resistant state.
According to the manual, you should not move the MacBook until the light starts pulsing. I assume this is because it hasn't engaged the sudden motion sensor yet to protect the drive from strong bumps that could otherwise cause a head crash & possible data loss.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,439
2 comentários
Problem is solved. thank you Mayer for your reply.
por yyweinberg
Glad I could help out.
por mayer
