Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
1984 Perguntas Visualizar todos
Why isn't my touch screen working after screen replacement?
I cracked my phone a couple weeks ago and got the screen replaced. Since then, I've been having trouble with my touch screen. It won't always register my touch, and sometimes it will move/type/click on something without me touching the screen. Before getting the screen replaced, even after the phone cracked, the touch screen worked perfectly. What could this be, and how can it be fixed?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
3 respostas
Did you make sure all ribbons and connectors were firmly in place when you replaced the screen? One possibility could be a loose cable. What you can try doing first is performing a restart a couple of times to see if it calibrates properly. Press and hold down the home button and power button simultaneously until the apple logo appears, then let go. Do this a few times, maybe 3, and see if it helps. If that doesn't help, then another possibility could be that the screen is faulty. If so, have it replaced.
Esta resposta foi útil?
Pontuação 0
Maybe some screws was mixed and install wrong lead to this issue.
Pontuação 0
Also this issue was present on iOS 11.3 when using an aftermarket LCD. You can try updating to 11.3.1. Sometimes it can fix this issue.
Pontuação 0
Adicionar a sua resposta
Bailey Smith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 67
