iMac Intel 27" EMC 2309 CPU Replacement
Hi,
I'm using an iMac Intel 27" EMC 2309 with a Intel Core 2 Duo E7600 processor. Is it possible to upgrade that and with what processor? Can you give any links?
Thanks
Esta é uma boa pergunta?
Hi,
Thanks
Sorry to say there are no upgrade options for the CPU.
The Core 2 Duo systems use a different socket than the i series CPU'ed systems (Lynnfield/Nehalem) which was also introduced at the same time.
Instead of trying to alter the CPU how about upgrading the RAM. And how about either replacing the HD with a SSHD which will give you some performance improvement or if you'er game, replace the optical drive for a second drive carrier and put in a SSD, and make it the boot drive. Then your system should really sing!
SSHD drive upgrade:
Dual Drive:
Produto
$19.99
Produto
$109.99
Produto
$30.99
Guia
Nível de dificuldade:
Fácil
5 - 10 minutes
Guia
Moderada
40 minutes - 2 hours
Guia
Moderada
1 - 2 hours
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 210
