Keyboard works only before OS boots, but not after
The laptop's keyboard responds when I press the power button. It also responds when I press Alt upon startup, to choose the startup disk.
However, it stops being recognised at all time, after the system boots.
Also, the trackpad fails to be recognised at all times: before AND after boot.
What is wrong here?
Is it a hardware problem?
EDIT I cleaned the connectors and here is the result: the keyboard WORKS all the time. But the trackpad never works.
Both external mouse and keyboard work.
However, The trackpad cable should not be to blame because it worked normally with the previous logic board that was in this laptop.
NOTE I just found out both Thunderbolt ports are not recognised, and the wifi card is not working (but Bluetooth works). Don't know if it's linked to the trackpad in any way
Esta é uma boa pergunta?
4 comentários
Do you have a USB keyboard and mouse to try out?
por Dan
Can you give us some background here on the system. Did you have a liquid spill at some point? Did you bang or drop the system?
por Dan
Does this laptop have water damage?
por Ethan Leroux
Haven't found any trace of water. No sticker has been triggered, and no apparent trace on the board
por Alex222
