Ir para o conteúdo principal
Why won't my computer turn on when plugged in w/battery in or out?
I tried turning my computer on while plugged in, but nothing no power indicator or anything. I removed the battery and tried turning it (still plugged in) and still nothing. I did forget my laptop in the trunk of my car for a couple of days, and I am concerned if it was affected by moisture.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Soooo many reasons could cause this, and the only way to be sure is to run a full diagnostic on it.
you could have a problem with your AC adapter.
you could have a problem with your power button
you could have an issue with the charger port,
you could have an issue with moisture
you could have an issue with board damage
I would try testing for each of those, in that order, to find out what you need to replace.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Daniel V será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 38
