Valve adjustment 1999 ford mustang 3.8l
Valve adjustment procedure
Esta é uma boa pergunta?
Jay Devin there is no valve adjustment on this engine, you just torque the rockers down. First tighten all the bolts to 44 lb/in then do it again at 26 lb/ft
Esta resposta foi útil?
@oldturkey03 what's the max speed of this pony?
unmodified it has a speed limiter at 115mph-118mph
Is the torque spec regardless of valve position?
fullerals yes it is
This should quiet noisy lifters ?
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 28
Duração total: 2,508
2 comentários
I have a 95 ford mustang with a 3.8 but the engine is a obd 2 like a 96 the car is 94/95 . Original engine and transmission no swap and been done I'm trying to find the timing and how to tighten the rocker arms is there a sequence in the firing order to it.. appreciate any help I can get I've been three years working on this and I can't seem to get the timing right ..
por Victor Rivera
Jay I have a convertible Mustang 2004 v6 3.8 motor what is the Valve adjustment procedure? Thank you
por Roy Salvatierra
