Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
604 Perguntas Visualizar todos
Can I add more RAM to an Early 2015 MacBook Air?
I just bought a used Early 2015 MacBook Air with 4GB of RAM. Can I upgrade it to 8GB?
Esta pergunta é pertinente?
Pontuação 2
Adicionar um comentário
1 Resposta
Solução escolhida
Hi Scollay,
According to this picture, the RAM is soldered onto the same board with the flash memory. It would not be easy to replace the RAM only.
Hope that helps!
Esta resposta foi útil?
Pontuação 4
1 dos comentários:
As @arthurshi stated, the MacBook Air systems all have soldered RAM.
You could swap out the logic board with one that has more RAM. Review this guide which lists the different boards: MacBook Air 13" Early 2015 Logic Board Replacement.
por
Adicionar a sua resposta
Scollay Petry será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 26
Últimos 30 dias: 93
Duração total: 7,928
