6s hex nut standoff screw
The repair for my 6s requires removing the 1 hex nut standoff screw.
Is it possible/easy to remove this without the exact tool? It seems this tool isn't included in most tool kits.
Thanks!
Esta é uma boa pergunta?
Thanks!
Some robust tweezers or needle-nose pliers should do the trick, the standoff is not very tightly secured. That said, using anything other than a proper driver could expose you to collateral damage so be extremely careful trying to remove it.
If you plan on doing this more than once, you should consider getting a driver before you do the repair.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 948
