iPhone 6 not booting
im having an issue with an iphone 6, when i got it, it was bootlooping, now i have replaced pmic, tristar and tigris. but doesnt boot. dc goes up and down but nothing past 0.09 amp
Esta é uma boa pergunta?
The first thing to consider is that possibly one of the IC replacements didn't work out, either through improper soldering or a defective component. The PMIC is not underfilled but is still a trickier job than a Tristar or Tigris.
At this point, you need to start probing the circuit to see if anything obvious needs to be addressed. Check all of the PMIC outputs. You could check for shorts, do diode mode measurement or read the voltage of the powered-on logic board. Whatever technique you prefer is fine, they each have their advantages and disadvantages. Don't neglect the Reset and I2C lines.
You should also check the entire Tristar and Tigris circuits.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 103
