Ir para o conteúdo principal
Hybrid laptop/tablet manufactured by Microsoft. Released November 2017.
35 Perguntas Visualizar todos
Individual key makes a "click" sound when pressed harder/faster
The A-key is affected on the surface book 2 keyboard, but only when pressing it harder than usual. It makes a "click" sound and as if it got stuck a couple of milliseconds. Not sure if this is a major problem as the button is still working and sounding not unusually when typing 'normally'.
Is it an issue with the rubber cup or key hinge/cap, or rather an issue with the key mount/ mounting clips, which are not easily replaceable with a key kit?
Esta é uma boa pergunta?
Pontuação 4
2 comentários
I am having the same problem with my A and Q keys on my surface book 2. Any luck?
por
Same here with the keys a, q and r. It drives me nuts. I want to love the device but paying for a premium device and receiving a typing experience worse then typing on a 10 bugs keyboard is just not acceptable. I'll return the thing if there is not solution to it. Did any of you figure something out?
por
Adicionar um comentário
1 resposta
Solução escolhida
Minor plastic spike in the key mechanism, not a problem in any way.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
H. H.C será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 730
