How to upgrade processor on 2009 education only iMac.
How do I upgrade my soldered on processor on my 2009 education only IMAC?
Esta é uma boa pergunta?
Sorry your only choice is to replace the complete logic board. Here's the needed logic board: iMac Alu 20" Logic Board, 2.0GHz (Edu) Apple P/N 661-5193 or if you live in the states: iMac Alu 20" Logic Board, 2.0GHz (Edu) Apple P/N 661-5193 As you can see its not too expensive less than $200 US.
Here's the IFIXIT guide you'll need to follow: iMac Intel 20" EMC 2266 Logic Board Replacement
Now do keep in mind this is a Core 2 Duo based system and Apple no longer supports it with the newer MacOS's El Capitan is the last OS this system will run. You may want to think long and hard before you spend any money on fixing this system if you think you'll want to get any newer apps. It might be wise to put the money towards a newer system (used or new).
Esta resposta foi útil?
Hi Dave,
If it’s soldered processor I am afraid that you can’t upgrade ( I seen few upgrades for soldered CPU / RAM but usually it not worth the money ).
Really good page for Mac’s is https://everymac.com/ultimate-mac-lookup... just put there your SN and you will see what you can/can’t upgrade etc...
Thank you so much for the video. I'll try to use it soon.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 1,301
