Ir para o conteúdo principal
Unable to activate Touch ID on this iPhone
Hello. I recently replaced a screen assembly on IPhone 6 and now the Touch ID doesn't work.
I moved the original home button onto the new screen and even bought a new flex cable . The home button is working fine but there's a message which says that the iphone is unable to active touch ID?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
4 respostas
Solução escolhida
Take a close look at the Home Button flex (the short one from the button to the connector) as well as the Link flex that goes beneath the LCD shield. It is possible that either the flex or one of the connectors was damaged or torn during the repair. If the link flex is torn or its connectors damaged, you can replace it again. If the Home Button flex or connector is damaged, it may be repairable but if the damage is too severe, you will have lost TouchID forever...or until you have Apple replace the screen and HB :>).
Esta resposta foi útil?
Pontuação 3
4 comentários:
Highly unlikely that it is the link flex.
por
@rocky85
We can only offer ideas and suggestions seeing as how we don't have access to the device itself to properly diagnose the issue. I have seen lot's of damaged link flexes following failed DIY repairs. It could be the connector or the link flex itself that gets torn. Either way, it doesn't hurt to look. Don't forget that the mission on this forum is to help fixers. Even if this doesn't perfectly answer the OP's question (and we rarely know because few people ever come back to say what helped or solved their problem), others will search for and find this answer and it may give them a good lead towards finding a solution.
As for your own answer, don't forget that the vast majority of replacement screens do not come with the link flex installed, it has to be transferred from the original screen to the replacement, hence why they tend to get damaged by fixers. On the iPhone 6S series, the link flex is embedded in the screen assembly.
por
@refectio Hello. Thanks always for the honest and in-depth answers :) I am currently working at a mobile phone repair shop and your replies are helping me hips with giving advice to my customers. I admire you so much. Thanks !
por
Thank you for the kind words @chrisp1989! Hopefully you will feel comfortable enough to start answering your own questions too.
por
uh oh! problem is, that apple has the touchid paired to the logic board, so unless you use the original touch id, its dead.
Pontuação 1
1 comentário:
Did not read question. Pointless answer.
por
Try on the old screen, see if it works, before buying a link flex cable.
Pontuação 0
1 comentário:
Didn’t think about that. I’ll check that out. Thanks
por
Try cleaning all associated connectors and the home button with isopropyl.
Pontuação 0
Adicionar a sua resposta
Arturs Ozolins será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 13,750
