Ir para o conteúdo principal
Released in 1999, successor to the original PowerMac G3, 300-450 MHz, 64 or 128 MB of RAM, 6 or 12 GB HDD
18 Perguntas Visualizar todos
Powermac G3 Hard Drive won't format for tiger installation
so, recent;y, i got a bigger hard drive for my powermac g3(10GB to 80GB) but when i enter disk utility, and do to the drive to format it, is starts, shows the status bar, and never makes it past 1/20 of the way there, disk utility never freezes, but after letting it attempt to format all night, it never made any progress, the computer isn't frozen, and the drive is good, but it won't format, I have also tried changing the jumper with no luck, any ideas?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Do you know if you've got a rev1 or rev2 B&W, if you've got a rev1 then the HD controllers aren't very stable and it could be it isn't compatible with your new drive.
There's a bit more info on the lowendmac site
http://www.lowendmac.com/ppc/blue-white-...
the rev2 have an IDE controller marked 402, which I think is down near the IDE plug, not 100% as our rev2 is a plane journey away, few years since I worked on it.
Esta resposta foi útil?
Pontuação 2
PowerMac G3 Blue and White can only support up to a 12 GB HDD
Pontuação -1
Adicionar a sua resposta
Chris Green será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 12
Duração total: 3,309
