Ir para o conteúdo principal
New screen; now incidentally backlight comes on but LCD does not
So I just installed a new screen from iFixit on my iPhone 5.
Now sometimes when I wake the phone the backlight comes on but the LCD does not i.e. the screen stays black but I can see the backlight is on. Until now the LCD does come on after a couple lock/wake cycles but this is not ideal.
Could this be a problem with the part or did I make a mistake installing the part?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Try reseating the cable.
por
Tried this, did not make a difference.
por
Adicionar um comentário
1 resposta
believing you disconnected the battery and did not cause any damage to the connections -try another screen. also if your old screen worked but was cracked reconnect it to ensure the connections work and no damage to board
Esta resposta foi útil?
Pontuação 0
1 comentário:
Unfortunately I tossed my old screen so I don't have another to try. Thing is, because it works properly most of the time I would think the connection does not seem to be the problem.
por
Adicionar a sua resposta
Ivar Meijs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 57
