Ir para o conteúdo principal
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
34 Perguntas Visualizar todos
Rainbow vertical lines when turned on
These lines show up for about 20 min then go away any idea what the problem is
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
May be a loose connection where when warmed up expansion occurs to create better contact.
Esta resposta foi útil?
Pontuação 1
@jmcubean could be an issue with bad caps or bad solder connections. Post some images of your boards with your question so that we can see what you see. Also, if you can post some images of what your panel first displays. Use this guide Adicionar imagens a uma pergunta já existente for that. Most vertical lines originate with failure of the T-con board or the main board.
Pontuação 1
Adicionar a sua resposta
Julianne será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 308
