no crank no start not sure how to tell where the problem is stemming
When I turn the key in the ignition all dash lights turn on however I don't recall hearing my fuel pump kick on as well as it doesn't even attempt to start. Along with those symptoms comes the fact that my transmission hasn't shifted properly in a long time this is the first time I've looked at it in about a year and when I last drove it it started and ran however that isn't the case anymore. So like I said I turn the key all dash lights come on and then nothing no crank no start no motor turning not even attempting I just put a different ignition coil on as well as spark plug wires I took my starter off and cleaned it and reinstalled it... Also see if anybody has a diagram with the exact location of the neutral safety switch and exactly step by step of what I need to do to bypass it it would help severely. I checked all relays and to the best of my knowledge I don't think any of them are faulty... Help please im stuck dead in the water!!!! Thanks
Esta é uma boa pergunta?
