Why won't my washer agitate? I hear it humming but does not agitate.
Why won't my washer agitate? I hear it humming but does not agitate. It does fill and drain fine but no agitation.
Esta é uma boa pergunta?
If your Kenmore 110 Series Washing Machine refuses to spin or agitate during the wash cycle, see the Kenmore 110 Series Washing Machine Doesn’t Spin or Agitate problem page for possible causes and solutions.
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 791
