Ir para o conteúdo principal
Introduced November 2012, this is a capable desktop computer with an Intel Core i7 3770S quad-core processor, 12GB of RAM, and a 3TB hard drive. It has a 23 inch, 1080p touchscreen and integrated Beats Audio.
HP Envy 27 - all in one - won't start
I actually have an HP Envy all in one 27 inch - p045 pc and it does not turn on.
Power cable works, and pc in back where it plugs in has a light. But nothing else.
I took the cover off, please notice the power switch and little board and cable that goes to PC/motherboard.
Is there a way to bypass or short switch to see if the pc will turn on, please take look. I want to make sure switch is working.
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
pcgeek these are real finicky about the power supply. They do require an original HP power supply and will not start without one. Did it ever work for you? Have you checked the power supply?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
I realized that opening the cover and just reseating the CMOS battery worked.
Esta resposta foi útil?
Pontuação 1
Same issue here. My PC froze and I pressed the power button for a few seconds to turn it off so that I can reboot it. But, it isn’t turning on now. The light next to the power cable is on in my case as well but it is white instead of green. When PC is running it would turn to orange. Couldn’t find a way to open the back cover so you did a really great job. I missed a critical project deadline because of this issue. My best bet is to take it to a repair shop.
Pontuação 0
Adicionar a sua resposta
pcgeek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 21
Ao todo: 4,179
