Ir para o conteúdo principal
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
52 Perguntas Visualizar todos
How to collapse piston in rear caliper on 1992 civic
i am trying to push the piston in the caliper in with a c clamp to change the pads. it will not budge. should it push in or am i missing something. both sides are the same. i removed the resevoir lid and even opened the bleeder screw to no results. thanks for any help.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
It takes a special tool. The piston needs to twist in. You should be able to barrow the tool from AutoZone for a deposet or you can buy 1. From this video I see you can also use a chissel like a screw driver to screw it back in.
Esta resposta foi útil?
Pontuação 3
1 comentário:
thank you so much. i kept looking at the slots in the piston thinking i was probably supposed to turn it. round 2 coming up.
por
a automotive file works GREAT you can get them anywhere for like $1.00
Pontuação 0
Adicionar a sua resposta
rich será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,176
