Ir para o conteúdo principal
The Asus X551CA is a 396.2 mm laptop computer with convenient features for everyday use.
29 Perguntas Visualizar todos
Why can't I see the SSD connected via USB port under "My Computer"
Hi all,
I decided to upgrade my Asus X550CA laptop with a Crucial SSD. I wanted to clone my existing hard drive however when I connected the SSD to my laptop via USB connector, I could not find it under My Computer.
I have tried to find am answer with no luck. When I go in disk management I can see the new SSD there in the bottom half. At the top half i see only C: and D: drives. Also, the driver for the new SSD is installed because I can see the SSD in Device Manager and I can elect it to unplug. So it seems that windows is not assigning it a drive letter. I have windows 8.1.
Has anyone one had a similar issue?
Thanks in advance,
GA
Esta é uma boa pergunta?
Pontuação 2
4 comentários
I am using EaseUS.
por
By the way, it is the free version of EaseUS. By initializing the disk do you mean I have to partition it?
Thanks
por
What if it states “NO Media” for the drive under Disk Management? I have already assigned a letter for the drive.
por
Hi @Elisha Satterfield
I suggest you start a new questions with more details to be noticed.
por
Adicionar um comentário
3 respostas
Solução escolhida
Actually I got it to work after watching a you tube video. In case someone runs in similar issue, the SSD needs to be initialized. I went in Disk Management, where my SSD showed as unallocated. Right click on it and choose New Volume. Then in the window that pop up check assign letter drive, format and that's it. Worked for me.
Esta resposta foi útil?
Pontuação 13
6 comentários:
This worked. Make sure you assign the drive letter or it still won't see it.
por
Thank you ^^ thought my cheap amazon cable was defective!!! <3
por
Thanks so much!
por
This worked with my new SSD Samasung EVO 870. This simple short suggestion was all that I needed after seaeching dozens of quasi complex suggestions on Google. Thank you author
por
same as above new evo 870, ty so much!
por
Exibir mais 1 comentário
Hi genti agastra , i suppose it is a new SSD, yes, if you see in disk management on the SSD device, means your SSD is detected on the computer.
The reason you are not seeing the Drive letter, is most probably, the disk is not initialized yet.
what software do you use for cloning?
most cloning software should be "smart" enough if you start the cloning, it will see this new SSD drive as the destination
Pontuação 2
Do you use the correct usb Cable?
Sometimes you need a two port Power usb to get the correct Power to the hdd.
Pontuação 1
1 comentário:
I have tried two types of USB to SATA connectors. I am pretty sure that is not the problem
por
Adicionar a sua resposta
genti agastra será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 85
Últimos 30 dias: 402
Duração total: 43,190
