Ir para o conteúdo principal
HP released this ergonomic laptop (model number 15-au123cl) in October 2016. It features Windows 10 and a touch screen.
14 Perguntas Visualizar todos
laptop battery doesn't reach 100% and laptop power off at 70%
i have hp pavilion 17t-ab000 CTO 17.3" laptop the battery doesn't fully charged and stop charging at 92% or 95% , then when i run my laptop at battery it powers off when battery shows as 70% charging within 20 minutes of web browsing should i replace that battery ? or there another solution
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If the laptop charger is correct, it's probably a problem with the battery. How old is your battery?
Esta resposta foi útil?
Pontuação 0
1 comentário:
As the seller said less than a month and i just installed new copy of windows then i detect that problem , before that i used it always plugged in
por
Adicionar a sua resposta
Moha Dabas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 330
