Ir para o conteúdo principal
Uma nova plataforma C-body com tração dianteira foi introduzida em 1985. O Fleetwood compartilhava a mesma distância entre eixos de 110,8 polegadas (281,4 cm) que os outros carros C-body: o de Ville, o Buick Electra e o Oldsmobile Ninety-Eight.
Car won't stay running
I have a 1987 Cadillac brougham rwd 5.0 and it is missing parts that seem to be usual with this car such as fuel filter,iac,and erg valve. My car was driving now I'm having trouble with it staying running it starts but will only stay on with my foot on the gas. I've checked for vacuum leaks and had not found any what else could be the problem? Please help. Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
If no fuel filter, then most likely your carb is full of crap. All those little holes and by passes are full of gum and gunk and that would do what you're describing.
Get a carby kit or get a professional to rebuild and reset it for you. Then you can install yourself if you want. Either way, I'm betting you need a rebuild.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Michael K Edmunds será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 15
Ao todo: 621
