Ir para o conteúdo principal
The DJI Phantom 4 Pro is a smart flying camera with forward and rear obstacle detection sensors and 28 minute flight time. It also features a better camera and every angle besides the top of obstacle avoidance.
10 Perguntas Visualizar todos
Little access door on one leg
I accidentally ran into a tree branch in the yard and it made the phantom 4 stop and it fell about 6 feet. One of the propellers were broken but I replaced that. A little access door on one of the legs popped off and it is not wanting to snap back on. I have tried but get to the point where I am afraid to force any more for fear of breaking it. Any suggestions?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Be sure the landing gear isn't broken at the leg where the screw cover came off. Sounds like the leg may be bent a little which is causing the cover to not fit properly. It should snap in after inserting the prongs into the bottom of the opening (with the drone right side up - top of the opening if it's upside down).
Esta resposta foi útil?
Pontuação 0
1 comentário:
Have same issue how do you bend leg back to close it properly? It goes back in place when you pull a little on the leg but don't want to break leg fell like plastic that may snap.
por
Adicionar a sua resposta
Pam Emelio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 447
