Why is my screen white after I replaced the lcd and digitizer?
I cracked my screen and ordered a replacement. Upon receiving my the new LCD and digitizer I carefully installed them and reassembled the iPod. Now, when I try to turn it on the screen is white. I tried to do a reset by holding the home button and screen lock button for 30 to 40 seconds, but that did not help. Any ideas of what I may have done wrong? Could it be a faulty part?
Thanks so much.
-Travis
Esta é uma boa pergunta?
9 comentários
I just tried to fix an ipod touch 4g with cracked glass. After a careful teardown and re-assemble I encoutered the same issue. I even tried connecting the old screen with the cracked glass but found the same white screen haunting me. I am going to try recboot but I am now wondering what to recommend to the customer I have. Any progress Travis?
por Bill Artz
Hey bill. I did eventually get mine to work but I ended up getting another new lcd from the same guy who sold me the first one. When I plugged in the second one it immediately showed up. If your having the same issue then out could possibly be a faulty lcd. I was also told the lcd and digitizer had to be fuzed together but they were incorrect cause mine works just fine in two separate pieces. I hope this helps! -travis
por Travis Mo
my iPhone 4s screen is comepletely white now and my dad bought a digitizer and lcd thing to fix it do you think this will solve the problem?
por craycareer
Hey
I got the same problem.
http://desmond.imageshack.us/Himg513/sca...
But if i put the old screen in, all works fine. But with the new I got this. I already reset the ipod etc but nothing seems to help.
What do I need to do?
Kind regards
por Willem
Recently, I bought iPod Touch 4 LCD Assembly from China after replacing it, my screen went to white only. Eventually, I realized that Digitizer connector is different from original one. The original one has wider plastic block in the middle of connector than faulty one from China. Do you think that the different connector makes white screen problem?
por Simon Pan
Exibir mais 4 comentários
