Pular para o conteúdo principal
Repair and disassembly guides for microwave ovens.
530 Perguntas Ver todas
Why does the turntable not rotate?
Unable to open case because screws are hex with a pin in the center that keeps a tors bit from unscrewing the screw. I would like to replace the motor for the turntable.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
What is the brand and model number of your microwave please?
por
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
2 Soluções
Solução escolhida
Here is a 96 Piece Security Bit Set that will help you crack the case on that sucker. Once inside, most microwave turntable motors are fairly simple to remove. I've heard that people go around scrounging them out of the trash because they're slow RPM motors that take 120v. Perfect for your disco ball or other slow rotating needs.
Esta resposta foi útil?
Pontuação 7
Comentários:
+ good answer. Disco Ball? ;-)
por
Every home should have one ;-)
por
I have a lava lamp, does that count? ;-)
por
dunno...do you dance round it?
por
only after listening to ABBA and to much Alvin Stardust ;-)
por
Mostrar mais 3 comentários
There are some security screws that protect the microwave from opening by everyone. The screwdrivers that open this class of screws are sold on any tool store like harborfreight.com or Enco. They are not difficult to find, but cannot be find everywhere as other screwdrivers can be found.
Pontuação 0
Adicionar a sua resposta
Edwin Weiss será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 4,498
