Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
465 Perguntas Visualizar todos
How can I upgrade my RAM?
My iMac has 4 memory slots - it came with 2 standard at 2GB each. I am thinking of adding more RAM so I want to figure out if it's going to work if I just add 1x4GB and leave one slot empty in case I'd like to add more RAM or I have to fill both free slots with 2GBs?
Thanks in advance.
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Your systems specs: iMac12,1
por
Adicionar um comentário
2 respostas
Pergunta Mais Útil
Fill it up with whatever you can afford. Big chips are bigly money, as Trump might say ;)
Apple recommended guidelines max out at 4 x 4 GB in each slot for a maximum of 16 GB of memory
for your machine specification. However, third-parties have discovered that it actually will support 32 GB of memory using 4 x 8 GB modules. This might shorten the lifespan of your board though. Boo!
You probably know: If not, This is the guide page how to do it.
iMac Intel 21.5" EMC 2428 RAM Replacement
If you can get your RAM off ifixit, return the favour:
PC3-10600 4 GB RAM Chip
PC3-10600 8 GB RAM Chip
Imagem de PC3-10600 4 GB RAM Chip
Produto
$29.99
Imagem de PC3-10600 8 GB RAM Chip
Produto
$44.99
Esta resposta foi útil?
Pontuação 2
Comentários:
Be careful!! The i3 CPU model can only go to 16 GB. The other factor is you need the newest system firmware (EFI) which was part of Sierra.
por
I bow to your deeper knowledge. Great Catch.
por
You really need to use two DIMM's but they don't need to be 2 GB modules. You can mix different pairs to the max of 16 GB.
Pontuação 1
Comentários:
So I can't leave one slot empty and just fill the other one with 4GB? I wouldn't like to add more than four.
por
Adicionar a sua resposta
Mark será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 193
