Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
MacBook Pro 13" Unibody Mid 2010, can the video card be upgraded?
Hello,
I have a MacBook Pro 13" Unibody Mid 2010, can the video card be upgraded in this model? (A1278) I've replaced the battery and doubled the ram from 4 to 8 GB. Any/all responses will be appreciated. Thanx for reading
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Not easily it is all part of the main logic board. The question is why? Card integrated was designed & developed for the board. If you have maxed out your RAM. You could put in a 2nd quicker hard drive. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive
No computer lasts forever, however well you maintain it or look after it. My advice would be to put any spare cash put towards a newer machine.
To squeeze any extra performance out of the machine the best thing you can do it to use a de-installer to remove any software you don't use on a regular basis. (I use Cleanmymac, but there are others out there.)
Plus don't have millions of files on the desktop use actual aliases. (CMD-L)
Esta resposta foi útil?
Pontuação 0
Sorry the GPU logic is part of the Haswell CPU and not upgradable in the 13" models.
The 15" MacBook Pro models have a dedicated GPU which offers better graphics performance.
To gain the best graphics performance you'll need to upgrade your system to a Thunderbolt2 or 3 based system and then use an external chassis to plug in a high end graphics board.
Pontuação 0
Adicionar a sua resposta
Lawrence Hoffman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 883
