upgrade ram mac mini server (mid 2011)
ho un mac mini server (mid 2011) con 8gb di ram, è possibile aumentarla a 16gb? se si quale è la migliore?
Esta é uma boa pergunta?
Standard RAM: 4 GB Maximum RAM: 16 GB*
Details: By default, 4 GB is installed as two 2 GB modules.
*Officially, this model supports 8 GB of RAM, but as first discovered by OWC, it actually is capable of supporting 16 GB of RAM using two 8 GB modules.
RAM Type: PC3-10600 DDR3 Min. RAM Speed: 1333 MHz
Esta resposta foi útil?
hi, the ram for mac mini mid 2011, can we use 1600 PC3-12800 - does it need to be low voltage model ?
This model uses:
Details: Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs.
noted on that, but do we have to use DDR3L or normal DDR3 ? thanks
Either will work!
The L is for low voltage option. This RAM will work in either normal or low voltage systems.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 895
1 comentário
I have a mac mini server (mid 2011) with 8gb of ram, you can increase it to 16gb? if which one is the best?
por mayer
