Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
381 Perguntas Visualizar todos
A1286 Logic Board & Top Case Cross-compatibility
So, I've got a late 2011 15" unibody MBP with an "irreparable" logic board. ("significant trace damage.") A buddy of mine has a mid-2012 15" unibody with a detached display. (not sure how this happened...) Assuming that whatever detached the display did not damage the display socket on the logic board, can I just drop the mid-2012 logic board into the late-2011 casing?
Actually, now that I'm thinking about it, is the top case cross-compatible, too? The keyboard on my late 2011 is a little wonky, and I wouldn't mind replacing it, if the part were free.
Pontuação 0
Adicionar um comentário
1 Resposta
Chosen Solution
It must be kismet here's the answer of the exact opposite! Take a look here: compatible logic boards late 2011 and mid 2012 model A1286. Basically you'll need to transfer the LVDS cable over. As far as using the uppercase thats OK too!
You do have a bit of work to pull this off and you still may need a few parts. Good Luck!
Pontuação 2
Add your answer
Joshua Vande Walle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 331
