Ir para o conteúdo principal
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
34 Perguntas Visualizar todos
My television is 6 years old and sometime the screen turns black after
my tv screen flickers and then turns black should i buy a new tv
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@nhafner27 you are not telling us if the picture comes back on by itself or if you have to turn the set of. This could be the backlight on your set turning off because of a bad power supply. Replacing all the boards inside your TV would probably be still cheaper than a new TV. I'd at least look a the boards for obvious damage etc. You can always post some pictures of your boards with your question so we can se what you see. Use this guide Adicionar imagens a uma pergunta já existente for that.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
natalie hafner será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 85
