Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3966 Perguntas Visualizar todos
Screen not responding after new screen replacement
My screen has been working fine for the year I had it then the other couple days I've noticed white lines on my screen but it still worked fine just yesterday it started acting buggy and slow and uunresponsive so I took it apart and reseated the digitizer without hard pressure at all and then it just continued to have crazy colorered lines sometimes the screen was completely black yes I disconnected the battery every time but I just put my new screen in and no lines but the first time the touch screen was barely responsive it moved one notification but barely but it just isn't responding. Also I connected the home button and it isn't working either. I need help I don't think I damaged anything
Pontuação 0
Adicionar um comentário
2 Respostas
Pergunta Mais Útil
I'm going to take a guess that the replacement screen is defective, very rarely a 5s will have touch issues being caused by the logic board.
Unless the touch screen connector is damaged or has liquid damage / corrosion near it you can check this by removing the black sticker that is around the screen connectors on the logic board.
Pontuação 1
Comentários:
I Was able to get it to work after 30 %#*@ tries of seating it correctly but my home button stil doesn’t work I connected it but it still won’t work
por
Home button issue can be caused by two things:
Connector on the home button connector being damaged, in this case charging port assembly would need to be replaced.
A tear in the home button cable itself, which would mean home button needing replacement and resulting in no touch id.
por
Hello I am not sure what is the problem but you can try to connect the I phone into a lap top. Then try to set it for I phone recovery mode. Then try to reset the I phone from the laptop. If that dose not work call Apple and I think they may be able to reset the scream and device if wirelessly. Good luck and hopefully it will work
Pontuação 0
Add your answer
dj holley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 573
