Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
439 Perguntas Visualizar todos
Washer doesn't fill with water on rinse cycle.
Kenmore washer does not fill with water for rinse cycle
Esta pergunta é pertinente?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
If the washer drains after washing but will not fill in the rinse cycle then checking the pressure switch would be a good idea. If the tub is empty you can remove the plastic hose, give the switch a thump and reattach the hose. Does it fill now?
If not then you can remove the violet wire and tan wire from the pressure switch and join them together with a small piece of insulated wire.
Remember to unplug the washer first before attempting this.
With these two wires connected the washer will fill if the pressure switch is the problem.
Esta resposta foi útil?
Pontuação 7
Comentários:
Did that and it worked!!!!
por
Found it to be the drainage hose was too far in the
drain pipe. Pulled out the drainage hose . I immediately heard a lot of gurgling and water started to drain
ran a cycle, and it worked like it should
so, pulling the hose out of the drain, and re-seating it,
resolved the issue
Pontuação 1
Adicionar a sua resposta
Cindy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 69
Últimos 30 dias: 316
Duração total: 15,829
