Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Red indicator over battery iPhone7
Hi guys!
I just bought a defect iphone 7 to inspect and repair (first timer). I've open the phone and I see this "RED indicator" which I guess (know) is some type of water damage. My question is.
Can I fix it? What should I look for?
Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
So, about 2 years in the future.
If you have the same problem as this thread holds.
I bought a new logicboard - replaced it and the phone worked perfectly. Till I smashed the screen and had to repair it once again.
por
Adicionar um comentário
2 respostas
Solução escolhida
Water damage is one of the hardest repairs.
it involves completely disassembling the phone,
iPhone 7 Rear Case Replacement
cleaning the water damage using alcohol
Electronics Water Damage
and a new battery.
iPhone 7 Plus Battery Replacement
Good luck!
Rice does not help with water damage!
Imagem de iPhone 7 Plus Battery
Guia
Nível de dificuldade:
Moderada
30 minutes - 2 hours
Imagem de iPhone 7 Rear Case
Guia
Difícil
2 - 3 hours
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you for the answer!
I will take it as the solution. Seems like I have work to do
por
It's water damaged phone. See all over phone you can see white spots, that is your water calcium.
Pontuação 0
Adicionar a sua resposta
Pontus Sennerstam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,240
