Smoke and burning smell coming from MacBook Pro. Will not turn on!
After charging, laptop shut down and would not turn back on. I could smell some burning circuits.
I broke the computer down and pulled the logic board. On the underside of the logic board I found a burnt piece labeled “R36 249 RR2” there are several of these chips. It even put a scorch mark on the underside material that sits under the logic board.
Is this a replaceable part or will the whole logic board fried? Also don’t know what the material under the logic board is covering up but I am worried about the scorch through the material.
Any help would be much appreciated.
Context:
Was uploading pictures to the computer from a SD card. After finishing and putting on the charger it was left for about an hour or so. Went back to finish what I was doing and there was nothing happening. Also when putting the charger on the led on mag pat lights up. Also when I press the button on the side of the computer next to the 6-7 led’s (that I assume are battery level indicators) they still show full green even though the computer will not turn on!
Here are some pictures!
UPDATE*
Better picture after gently cleaning with IA as recommended:
Esta é uma boa pergunta?
