Ir para o conteúdo principal
The Samsung S860 is a high resolution digital camera with 8.1 megapixels, 3x optical zoom, Samsung SHD Lens, 2.4-inch LCD screen, and Digital Image Stabilization (DIS).
Samsung S860 wont come on and lens wont extend?
My camera wont turn on and the green light at the back flashes when I hold the on button. never had this issue before please advise what to do
Tony
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I don't know the exact answer but you could try checking the batteries.
Another is take out the batteries and then press"On" button for 15 seconds or more.
Put in know good batteries and see if works.
This is generally the first step for troubleshooting anything electronic.
Update (02/13/2018)
Does the lense retract when you remove the batteries?
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi Mike, I have brand new batteries and the lens came out and the screen lite up and then went out and now nothing works its stuck-but the green indicator light blinks when I press the on / Power button. I am stumped. This camera has been very efficient in the past, something has gone bannanas Can you suggest another tactic other than Junk it?
por
have you found a solution?
por
Adicionar a sua resposta
piscopot@hotmail.com será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 558
