Ir para o conteúdo principal
Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
20 Perguntas Visualizar todos
dark side of 40 inch Samsung tv
left side of screen is black but brightens up after a bit and also looks like tracers from the objects showing in tv
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Chad Ross post some images of what your screen displays. Use this guide Adicionar imagens a uma pergunta já existente for that. It will allow us to see what you see. If your screen clears up and shows properly after a while then it is most likely a capacitor issue most likely on the power board but possibly on the t-con board as well. Verify that your TV is a Samsung LA40R81BD
por
Adicionar um comentário
1 resposta
You just have to let it warm up until you're able to find a permanent solution.
Esta resposta foi útil?
Pontuação 0
3 comentários:
I have tried it but to no avail. Thank u
por
No problem. I have no clue about TVs. LOL
por
I won't delete this answer though because some people might want to see that its NOT the solution XD
por
Adicionar a sua resposta
Chad Ross será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 746
