Ir para o conteúdo principal
Repair guides and support for motherboards and CPUs.
165 Perguntas Visualizar todos
Wont post, wont do anything, just one green LED.
Details:
old motherboard: ASUS P4T-E
old GPU: ATI Radeon 7500
old RAM: 2x Sim Tech C-RIMM 0150 Continuity RIMM module, 2x Samsung 800-45 256MB RAM
old CPU: Intel Pentium 4
its all dead except for 1 little green LED on the MB. no post codes, no display, no fans, no nothing.
I'm stumped.
@avanteguarde @danj @paperboypaddy any ideas?
power button does nothing. reset button does nothing either.
Update (02/07/2018)
Pictures:
Esta é uma boa pergunta?
Pontuação 1
7 comentários
@oldturkey03 I'm wondering do you have any experience in PCs?
por
@captainsnowball that is a depend. Depends on what you got and what the issues are. I do not deal with any software issues and consider those not-repair related.
por
Any ideas then?
por
Yikes why do you have the power supply open?!
por
Yeah don't mess with PSUs.
por
Exibir mais 2 comentários
Adicionar um comentário
5 respostas
Solução escolhida
Hi Aiden,
If your computer is running slower than usual, randomly freezes or restarts, or refuses to boot, see the Motherboard Has a Faulty Capacitor problem page for capacitor troubleshooting help.
Have you tried unplugging the power cable and shorting the physical pins on the board for the power switch? You could potentially just have a bad switch or one that isn't connected properly. Here's a link to the motherboard. Page 42 covers the front panel header, though I would review this manual in more depth. I'm seeing some DIP switches that I haven't seen on a computer in a while, so make sure you have those dialed in for stock speeds settings before attempting to boot and make changes. Have you attempted a full disassembly and reassembly with only the CPU, GPU, and RAM installed?
- Jasen
Esta resposta foi útil?
Pontuação 2
19 comentários:
Its only the motherboard itself. with the GPU RAM and CPU in.
por
What should I set it to?
por
Ok if it's just those components, did you try starting the machine by shorting the two front panel pins that are assigned for the power button?
por
Yes. I have the front panel connected I'll add a pic.
por
Go to page 18 in the manual, try alternating the jumper setting for JumperFree and JumperMode, and powering the machine on with either option set. And ok, great. A pic would greatly help!
por
Exibir mais 14 comentários
If it has built in graphics, try those. Even unplug the the VGA power cable. (That's what they used to call a GPU in the old days.)
I hope you're fluent in google translate: https://www.asus.com/supportonly/P4T-E/H...
Update (02/08/2018)
@captainsnowball you got a CPU heatsink? Many PC's won't even boot if you don't have a CPU fan and system fan.
Pontuação 0
Picture # 5.... It seems that the "power" thing is crooked. I am new to things like this, but I think that could be part of the problem. And there is a lot of dust. Maybe try cleaning it?
Pontuação 0
2 comentários:
That's the power switch header. Looks like it's fine.
por
Hmm.....I don't know whats wrong, but I'll keep examining the pictures for you.
por
First: Close that PSU now. This is horribly dangerous, if you touch the wrong part and unload a capacitor you can kill yourself.
There is also a very good chance it wont post because there is no CPU cooler mounted. A CPU requires a specific amount of pressure to make contact with the socket.
Even if it would turn on, it would overheat within 20 seconds and shut down again. On older CPU's this can be fatal to the CPU.
So: Mount the Cooler, and make sure it fits properly (No wiggling). And make sure you use thermal paste.
Pontuação 0
Hi. My name is dinu and i have a pc problem.
I am currently buildimg a pc. When i plugged the 24 pin the fans were already spinning (even from gpu) and i got 2 red Led glowing (cpu led), then i plugged the 8 pin connector for cpu power. Now I’m getting a green Led, no sign of life. I’ve already tried to use the phisycal pins instead of the power button. Still not working.
Pls help
My motherboard is an intel zx58so
Cpu: intel i7-920
Amd 6970 Sapphire
Pontuação 0
Adicionar a sua resposta
Aiden será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 30
Duração total: 1,795
