SSD problem can't format
Out of nowhere suddenly my MacBook Pro got into the folder with blinking question mark mode and I wasn't able to boot.
I then started up from internet recovery, it seems that my SSD is messed up. In the process of erasing it, it got into an error like "waiting for disks to reappear"
At that point I took out the SSD and used an adaptor to connect to other Mac, still I can't erase the disk using MacOS GUID partition mapping and create a journal format partition from the other Mac while formatting,
Wiping volume data to prevent future accidental probing failed - Operation failed!
Update (02/08/2018)
images of my ssd and some terminal usage to check functionality of ssd
Esta é uma boa pergunta?
ssd is able to create partitions through pdisk
por S SAI SANTHOSH
I was hoping you had a Toshiba unit Apple recall: MacBook Air at risk of catastrophic SSD failure as it had a recall a few found their way into MacBook Pro's. The recall has ended but it would have explained things.
At this point I thing you'll need to visit an Apple Store to see if they have any tricks up their sleeves. IT does appear you have a few partitions which is messing things up I was hoping you could have nulled the drive and then created a fresh partition map & partition (MacOS).
por DanJ
how to null the drive and create fresh partitions!? can you guide me or link to the process :)
por S SAI SANTHOSH
Thats what we did already using FDISK deleting the partitions. As I explained above.
Just use FDISK to remove all of the partitions from a different system via Target Disk Mode or using an external case to hold the SSD, don't make any partitions!. Then pop the drive back into your system if needed and use a bootable OS installer USB thumb drive following this: How to create a bootable macOS Sierra installer drive. Then use Disk Utility from it to create the GUID partition map and setup the Journaled partition (only one). Then run the OS installer to install a clean OS.
por DanJ
I did that using fdisk.. it stated no partition map exists.. then i plugged it back to create one journaled partition but still no hope.. it again stuck at waiting for partitions to activate
por S SAI SANTHOSH
Exibir mais 3 comentários
